Jul 12, 2021Guru - Experienced User
New - RBK752/753 Firmware Version 4.6.3.7 Released
Security Fixes: Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. New Features and Enhancements: Supports Smart...
- Sep 13, 2021
***Updated: 9/13/2021 11:50 AM PT
Hello Orbi Community,
Please accept my apologies for any delay in getting this message to you. I have been advised that an official firmware release is in the final stages of internal testing and in the process of being posted to our support site. Likely, within the next 24 hours.
To get this firmware release now please click the link below:
For instructions on how to manually download this firmware please visit:
How do I manually upgrade firmware on my Orbi router using orbilogin.com?
Thank you for your patience,
ChristineT
intergeek14
Aug 26, 2021Star
Now the original ORBI71 set up SSID is showing along with net gear guest network even though it’s turned off in the settings. Yes, I can connect to them using the main SSID password….. Here comes my 5th factory reset.
Aug 26, 2021Guru - Experienced User
What happens if you re-enable it then disable it on the RBRs web page?
