Jul 12, 2021Guru - Experienced User
New - RBK752/753 Firmware Version 4.6.3.7 Released
Security Fixes: Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. New Features and Enhancements: Supports Smart...
- Sep 13, 2021
***Updated: 9/13/2021 11:50 AM PT
Hello Orbi Community,
Please accept my apologies for any delay in getting this message to you. I have been advised that an official firmware release is in the final stages of internal testing and in the process of being posted to our support site. Likely, within the next 24 hours.
To get this firmware release now please click the link below:
For instructions on how to manually download this firmware please visit:
How do I manually upgrade firmware on my Orbi router using orbilogin.com?
Thank you for your patience,
ChristineT
jdk1120
Aug 27, 2021Apprentice
After turning my AX setting off, my router & satellites appear to be more stable. I haven't tinkered around with change the IP address or the power setting on 2.4ghz, but hopefully this is sufficient until the new firmware comes out.
In related news, Netgear escalated support has completely ghosted me. I'm thinking of opening a new ticket so that support can be started as my 90-day warranty window is closing soon.
Gtjacket
Aug 27, 2021Tutor
jdk1120 wrote:After turning my AX setting off, my router & satellites appear to be more stable. I haven't tinkered around with change the IP address or the power setting on 2.4ghz, but hopefully this is sufficient until the new firmware comes out.
Good to hear. Unfortunately deactivating AX did not improve anything for me. Ultimately, I think there are several distinct issues being discussed on this thread. Personally, my issue is one of my two sattelites is constantly disconnecting from the base after the upgrade. I constantly see the famous green then blue light on it. Messing around with IP space/DCHP should not make any difference in Sattelite connectivity to the base from a technical standpoint. I did have some issues with end points and I think that can be attributed to the IP address range issues.
Since I was having more problems with one sattelite than the other, I moved the troublesome one closer to the base as a test and it definitely has improved the number of times it resyncs but it is still numerous times a day vs constantly in the old location. This leads me to think that the software upgrade greatly reduced the range for the backhaul link. If this is the case then it defeats the purpose of the mesh system as the I am not getting the coverage needed in my house. Definitely a huge step back in performance vs the older code.
Has anyone else who has had the sattelite disconnect issue, tried playing around with location and seen any differences as well?
