Jul 12, 2021Guru - Experienced User
New - RBK752/753 Firmware Version 4.6.3.7 Released
Security Fixes: Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. New Features and Enhancements: Supports Smart...
- Sep 13, 2021
***Updated: 9/13/2021 11:50 AM PT
Hello Orbi Community,
Please accept my apologies for any delay in getting this message to you. I have been advised that an official firmware release is in the final stages of internal testing and in the process of being posted to our support site. Likely, within the next 24 hours.
To get this firmware release now please click the link below:
For instructions on how to manually download this firmware please visit:
How do I manually upgrade firmware on my Orbi router using orbilogin.com?
Thank you for your patience,
ChristineT
Aug 24, 2021Guru - Experienced User
I agree and asked them about this.
Can't presume to know what developers are doing.
No router mfrs announces when new FW is forth coming.
raven_au wrote:
FURRYe38 wrote:
You guys can try this:
FW fixes don't happen over night.
But removing the current broken version so that people don't get the broken update pushed onto them or simply not advertising the broken version seems like the sensible thing to do.
Since they haven't done that you have to conclude they aren't taking the complaints seriously or simply don't believe the problems are serious since the developers obviously never use the routers themselves.
So when will there be an update to help with this ... one year ... two ...
Timothy88
Aug 29, 2021Luminary
I have an RBK752 system running firmware version 4.6.3.7 and am seeing the router disconnect and turn magenta. I have a wired connection to the router and am unable to connect to any devices on the LAN or access the internet while in this state. If I launch the app it shows the status of the router to be red/disconnected. I can recover by using the Orbi app on my phone and rebooting the router once the router reboots then everything is good. Is this yet another problem with the firmware? Any ideas on what may help stabalize this or do I have to go back to my time capsule until Netgear can get it fixed? Any ideas on when Netgear will be releasing a fix for this debacle of an update?
- FURRYe38Aug 29, 2021Guru - Experienced User
- Gatorade2000Aug 29, 2021ApprenticeAll the 300 posts are about this. return your orbi as it may crap up on you when you need the most.
- Timothy88Aug 29, 2021Luminary
In other words just go back to my 10 year old time capsule.
- AtllawAug 29, 2021StarOr just buy something else without the problems. Or you can spend hours trying to figure out the problem and then return it in a couple of weeks. Wondered how many of these have been sent back to Amazon and Costco over the past month?
