Jul 12, 2021Guru - Experienced User
New - RBK752/753 Firmware Version 4.6.3.7 Released
Security Fixes: Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. New Features and Enhancements: Supports Smart...
- Sep 13, 2021
***Updated: 9/13/2021 11:50 AM PT
Hello Orbi Community,
Please accept my apologies for any delay in getting this message to you. I have been advised that an official firmware release is in the final stages of internal testing and in the process of being posted to our support site. Likely, within the next 24 hours.
To get this firmware release now please click the link below:
For instructions on how to manually download this firmware please visit:
How do I manually upgrade firmware on my Orbi router using orbilogin.com?
Thank you for your patience,
ChristineT
Gatorade2000
Aug 30, 2021Apprentice
speedtest on a web browser is accurate only if directly connected with an ethernet cable to the router. No third party app is reporting close speeds otherwise(on wireless)
Aug 30, 2021Guru - Experienced User
I found that web browsers can effect speeds as well. Sometimes all those Ads cause slow downs. I prefer to use Ooklas speed test app for Windows and Mac for best accurate speed testing:
- AK_NGAug 30, 2021TutorTo keep it very simple , All my speed tests for orbi were from wire/ethernet cable plugged to the RBR750 router that's connected to Verizon modem.
I used the Ookla site via browser on my desktop connected via ethernet- this was what netgear support also mentioned and not use either of the speed tests that come in orbi app or web gui although I have seen very similar results on those as well for speed tests.- FURRYe38Aug 30, 2021Guru - Experienced User
Hopefully NG is fixing this on there side.
Seems maybe they are starting too. I beleve it was mentioned that this was NG cloud issue that is something that is nof fixed in FW, rather on there services.
- AK_NGSep 05, 2021TutorI finally got a call from netgear customer support with a beta FW ver . I was able to update to new beta fw ver manually for the mesh and the slowness issue is resolved. The speeds are now consistent in 900 mbps . Did not notice any issues for past day or so with new beta ver which is a good news.. Hopefully netgear will send new ver fw to others also that are facing issues with new fw update soon.
- Timothy88Sep 05, 2021Luminary
I wonder if that beta release addresses the unit losing connection, going offline (indicator light turns magenta) and basically goes unresponsive to all LAN traffic until it's rebooted?
