Jul 12, 2021Guru - Experienced User
New - RBK752/753 Firmware Version 4.6.3.7 Released
Security Fixes: Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. New Features and Enhancements: Supports Smart...
- Sep 13, 2021
***Updated: 9/13/2021 11:50 AM PT
Hello Orbi Community,
Please accept my apologies for any delay in getting this message to you. I have been advised that an official firmware release is in the final stages of internal testing and in the process of being posted to our support site. Likely, within the next 24 hours.
To get this firmware release now please click the link below:
For instructions on how to manually download this firmware please visit:
How do I manually upgrade firmware on my Orbi router using orbilogin.com?
Thank you for your patience,
ChristineT
PhredP
Aug 31, 2021Aspirant
I have been using a Cisco 2 line ATA voip device with Voicepulse without problems for many years. With this new bios, the ATA will only register and connect if it is in the DMZ. Once registered, if moved out of the DMZ, it can call out, but won't receive calls.
The "Disable SIP ALG" box is checked.
Is anyone else having an issue with voip on this new Orbi RBR750 bios?
Aug 31, 2021Guru - Experienced User
"The "Disable SIP ALG" box is checked" something you changed or has then been always like this? What happens if you take the check mark out and apply the change for this feature with the VoIP device no in the DMZ?
You can leave the VoIP device in the DMZ, won't be a risk. Something I've done before.
Has a factory reset and setup from scratch been performed since last firmware update?
- PhredPAug 31, 2021Aspirant
Thank you for the quick response. The "Disable SIP ALG" was always checked (unless I was checking alternatives).
I just rebooted the voip ATA after switching it out of the DMZ. And after a week of tech support emails and changing firmware and configurations on the ATA. They got it working in DMZ, then it couldn't receive calls when switch out of the DMZ. I just rebooted the ATA, and that seems to have fixed everything, at last.
If problems return, the ATA will go back in the DMZ.
So for now, I am treating this problem as solved......
- FURRYe38Aug 31, 2021Guru - Experienced User
Ok kewl. Glad it's working again. Sometimes VoIP can be picky. Keep an eye on it.
Enjoy.
