Jul 12, 2021Guru - Experienced User
New - RBK752/753 Firmware Version 4.6.3.7 Released
Security Fixes: Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. New Features and Enhancements: Supports Smart...
- Sep 13, 2021
***Updated: 9/13/2021 11:50 AM PT
Hello Orbi Community,
Please accept my apologies for any delay in getting this message to you. I have been advised that an official firmware release is in the final stages of internal testing and in the process of being posted to our support site. Likely, within the next 24 hours.
To get this firmware release now please click the link below:
For instructions on how to manually download this firmware please visit:
How do I manually upgrade firmware on my Orbi router using orbilogin.com?
Thank you for your patience,
ChristineT
jaideepdoc
Sep 04, 2021Guide
Hi
I have the RBK 752 set up at home. the current firmware is V4.6.3.7.
I am facing the following issues
Devices are getting disconnected from the satellite unit
Devices on the satellite unit get message no wifi
When trying to reconnect the devices option as Orbi guest is shown but my guest option is off
The satellite seems to be getting disconnected from the main unit often since i see it booting again and frequently see the light flashing
thanks
Gatorade2000
Sep 04, 2021Apprentice
try burning the unit.
- Timothy88Sep 04, 2021Luminary
Ok what am I missing? I tried adding the keywords to block the auto update and the satellite went back to V4. Also in safari how do you enable the YES button so you can donwgrade?
- Gatorade2000Sep 04, 2021Apprenticeread this thread, it is one of the F keys
- FURRYe38Sep 04, 2021Guru - Experienced User
Then do this on the RBR:
So this is what Netgear support is providing as a means for downgrading? It still doesn't solve the Yes button problem.
