Jul 12, 2021Guru - Experienced User
New - RBK752/753 Firmware Version 4.6.3.7 Released
Security Fixes: Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. New Features and Enhancements: Supports Smart...
- Sep 13, 2021
***Updated: 9/13/2021 11:50 AM PT
Hello Orbi Community,
Please accept my apologies for any delay in getting this message to you. I have been advised that an official firmware release is in the final stages of internal testing and in the process of being posted to our support site. Likely, within the next 24 hours.
To get this firmware release now please click the link below:
For instructions on how to manually download this firmware please visit:
How do I manually upgrade firmware on my Orbi router using orbilogin.com?
Thank you for your patience,
ChristineT
Gatorade2000
Sep 04, 2021Apprentice
try burning the unit.
Timothy88
Sep 04, 2021Luminary
Ok what am I missing? I tried adding the keywords to block the auto update and the satellite went back to V4. Also in safari how do you enable the YES button so you can donwgrade?
- Gatorade2000Sep 04, 2021Apprenticeread this thread, it is one of the F keys
- FURRYe38Sep 04, 2021Guru - Experienced User
Then do this on the RBR:
- Timothy88Sep 04, 2021Luminary
So this is what Netgear support is providing as a means for downgrading? It still doesn't solve the Yes button problem.
NG doesn't support this as it's not official. A user found this to downgrade his system. Up to users if they want to try it or not.
