Jul 12, 2021Guru - Experienced User
New - RBK752/753 Firmware Version 4.6.3.7 Released
Security Fixes: Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. New Features and Enhancements: Supports Smart...
- Sep 13, 2021
***Updated: 9/13/2021 11:50 AM PT
Hello Orbi Community,
Please accept my apologies for any delay in getting this message to you. I have been advised that an official firmware release is in the final stages of internal testing and in the process of being posted to our support site. Likely, within the next 24 hours.
To get this firmware release now please click the link below:
For instructions on how to manually download this firmware please visit:
How do I manually upgrade firmware on my Orbi router using orbilogin.com?
Thank you for your patience,
ChristineT
Wyatt381
Sep 08, 2021Tutor
Question for claification ... I am a FIOS user on 1GB plan and I currently have been using my Orbi in router mode recieving great speeds over wifi and with throughput over ethernet. Just like everyone else once this new FW 4.6.3.7 Released my overall speed have take a massive dump. Wifi AVG 90 up /75 down and Ethernet is showing about the same. However. when I use an old FIOS gateway incoming speed is still showing 940 down /900 up coming into the house. My question is anyone using their Orbi in AP mode instead of router mode using my old FIOS gateway still having these wifi speeds issue. WFH need help.
Sep 08, 2021Guru - Experienced User
Are you speed testing using the RBRs build in speed test app or Orbi app or are you speed texting using external speed test apps like Ooklas installable speed test app on a PC or device?
- Wyatt381Sep 08, 2021Tutor
Both. Using speedtest installed App on machine and using fast.com to test speeds coming from the Orbi.
- FURRYe38Sep 08, 2021Guru - Experienced User
Ok, others reported as I've seen as well that onboard speed test and orbi app report less results than external ones. I use Ooklas and see to spec speeds. NG is aware of this.
You can try getting the beta from NG support and see if this changes what your seeing.
Do you think trying to use my Orbi in AP vs router mode will fix these speed issues?
