Jul 12, 2021Guru - Experienced User
New - RBK752/753 Firmware Version 4.6.3.7 Released
Security Fixes: Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. New Features and Enhancements: Supports Smart...
- Sep 13, 2021
***Updated: 9/13/2021 11:50 AM PT
Hello Orbi Community,
Please accept my apologies for any delay in getting this message to you. I have been advised that an official firmware release is in the final stages of internal testing and in the process of being posted to our support site. Likely, within the next 24 hours.
To get this firmware release now please click the link below:
For instructions on how to manually download this firmware please visit:
How do I manually upgrade firmware on my Orbi router using orbilogin.com?
Thank you for your patience,
ChristineT
michsu
Sep 08, 2021Apprentice
Sorry, I meant that the beta firmware still has a problem. The orbi app and frontier app sees the 900+/900+ now, not the speedtest done on speedtest app, fast.com and others still cap me at 600.
Sep 09, 2021Guru - Experienced User
Besure you power OFF the ISP Modem for 1 minute, factory reset the RBR and RBS after loading the beta FW, power ON the ISP modem then setup the RBR and RBS from scratch. Other users ARE reporting that the speed test results are fixed on the Orbi app and on board RBR speed test app. The 7 series is cable of near 900Mbps or just over ON wired ethernet only. The ethernet ports are 1000Mpbs connection rated ONLY so you'll not see anything much over 950Mpbs at all due to the LAN Ports being 1000Mpbs. Same goes for the 8 series, however the 8 series CAN seen over 1000Mbps speeds on wireless since the WAN port on 8 series is rated at 2.5Gb and wireless connection rates support up to 2400Mpbs on 5Ghz AX. And if you have a AX supporting devices that supports 2400Mbps 4x4 MIMO.
