Jul 12, 2021Guru - Experienced User
New - RBK752/753 Firmware Version 4.6.3.7 Released
Security Fixes: Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. New Features and Enhancements: Supports Smart...
- Sep 13, 2021
***Updated: 9/13/2021 11:50 AM PT
Hello Orbi Community,
Please accept my apologies for any delay in getting this message to you. I have been advised that an official firmware release is in the final stages of internal testing and in the process of being posted to our support site. Likely, within the next 24 hours.
To get this firmware release now please click the link below:
For instructions on how to manually download this firmware please visit:
How do I manually upgrade firmware on my Orbi router using orbilogin.com?
Thank you for your patience,
ChristineT
MaleHumanUK
Sep 13, 2021Star
I would not get too excited about the Beta. I have been running it for a few days now, and the satellite stability issue is no better for me - if anything it seems worse.
- scottyincoSep 13, 2021Tutor
Bummer. Guess back to Costco mine go. Wonder how many returns Costco is getting of these?
MaleHumanUK wrote:I would not get too excited about the Beta. I have been running it for a few days now, and the satellite stability issue is no better for me - if anything it seems worse.
- intergeek14Sep 13, 2021StarDid you do a full reset? I did a full reset and the beta has been great. Think the speeds for each device has been better than when I first purchased this set up. I have 2 satellites and they hand off devices much better now.
- FURRYe38Sep 13, 2021Guru - Experienced User
Yes, ensure you have done a full factory reset on the RBR and RBS. After setting up the RBR and RBS again. Power OFF the RBR and RBS and ISP modem/ONT for 5 minutes then back ON with the ISP modem/ONT first then RBR then RBS.
