Jul 12, 2021Guru - Experienced User
New - RBK752/753 Firmware Version 4.6.3.7 Released
Security Fixes: Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. New Features and Enhancements: Supports Smart...
- Sep 13, 2021
***Updated: 9/13/2021 11:50 AM PT
Hello Orbi Community,
Please accept my apologies for any delay in getting this message to you. I have been advised that an official firmware release is in the final stages of internal testing and in the process of being posted to our support site. Likely, within the next 24 hours.
To get this firmware release now please click the link below:
For instructions on how to manually download this firmware please visit:
How do I manually upgrade firmware on my Orbi router using orbilogin.com?
Thank you for your patience,
ChristineT
RayBan_21
Sep 14, 2021Star
ChristineT Just a quick question; does the linked file differ from the beta that was distributed? Just wondering if it's worth doing another upgrade, reset, etc. Thanks!
Engladian
Sep 14, 2021Tutor
FWIW, I just saw that 4.6.3.16 has been officially released and I installed it on my system. The speed test on the Orbi app and the router web page now seems to be correct again. I can't speak to if this resolved other problems since this was ther main issue I was seeing.
- FURRYe38Sep 14, 2021Guru - Experienced User
Good to hear. Have you done a full power OFF of the system for 1 minute then back ON or done any factory reset after the FW was updated?
- wjbridgeSep 14, 2021Star
Yes, I supplied them with multiple logs both from the satellite and router but definitely not the only person who experienced this problem based on these 19 pages of forums :).
- EngladianSep 14, 2021Tutor
No, not yet. System seems to be stable (knock on wood) right now but if I see any issues I'll take that step.
