Jul 12, 2021Guru - Experienced User
New - RBK752/753 Firmware Version 4.6.3.7 Released
Security Fixes: Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. New Features and Enhancements: Supports Smart...
- Sep 13, 2021
***Updated: 9/13/2021 11:50 AM PT
Hello Orbi Community,
Please accept my apologies for any delay in getting this message to you. I have been advised that an official firmware release is in the final stages of internal testing and in the process of being posted to our support site. Likely, within the next 24 hours.
To get this firmware release now please click the link below:
For instructions on how to manually download this firmware please visit:
How do I manually upgrade firmware on my Orbi router using orbilogin.com?
Thank you for your patience,
ChristineT
ddkumar
Sep 14, 2021Star
Netgear pushed software v4.3.16 to my Orbi RBK752 early today. The version on the website Firmware Downloads page is still the older version v4.3.7. I don't appreciate having software pushed to my system that isn't even on the Downloads page. First impression is that the device disconnect problem seems better, but it is too soon to be sure. I had already used the 2.4GHz power reduction trick (lowering 2.4GHz power creates less of signal overlap with the router and satellite and definitely helped my problems with v4.3.7). The router internal speed test seems better (used to top out at ~600Mbs) but still does not reflect my full Xfinity gigabit service capability, which used to benchmark using the internal test around 1.2Gbs. Now the internal test seems to tap out in the 900Mbs range. I will test at a later time in the event there are some network load issues.
Sep 14, 2021Guru - Experienced User
Do a pull power OFF of the system for 2 minutes then back ON. Include the ISP modem/ONT in this as well.
