Jul 12, 2021Guru - Experienced User
New - RBK752/753 Firmware Version 4.6.3.7 Released
Security Fixes: Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. New Features and Enhancements: Supports Smart...
- Sep 13, 2021
***Updated: 9/13/2021 11:50 AM PT
Hello Orbi Community,
Please accept my apologies for any delay in getting this message to you. I have been advised that an official firmware release is in the final stages of internal testing and in the process of being posted to our support site. Likely, within the next 24 hours.
To get this firmware release now please click the link below:
For instructions on how to manually download this firmware please visit:
How do I manually upgrade firmware on my Orbi router using orbilogin.com?
Thank you for your patience,
ChristineT
Engladian
Sep 14, 2021Tutor
No, not yet. System seems to be stable (knock on wood) right now but if I see any issues I'll take that step.
Sep 14, 2021Guru - Experienced User
- ddkumarSep 14, 2021Star
Late update...
The internal speed test is now showing full throughput, which in my system maxes out at 1.4Gbs (through a LAG bonded cable modem). This is equivalent to the result I was getting with the old stable firmware release. Hurrah! I have also not experienced the endpoint disconnect when switching between the router and the satellite in the newly pushed firmware. I haven't turned AX back on yet.
- FURRYe38Sep 14, 2021Guru - Experienced User
Good to hear. Can try enabled AX mode and see how it goes...
ddkumar wrote:
Late update...
