Jul 12, 2021Guru - Experienced User
New - RBK752/753 Firmware Version 4.6.3.7 Released
Security Fixes: Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. New Features and Enhancements: Supports Smart...
- Sep 13, 2021
***Updated: 9/13/2021 11:50 AM PT
Hello Orbi Community,
Please accept my apologies for any delay in getting this message to you. I have been advised that an official firmware release is in the final stages of internal testing and in the process of being posted to our support site. Likely, within the next 24 hours.
To get this firmware release now please click the link below:
For instructions on how to manually download this firmware please visit:
How do I manually upgrade firmware on my Orbi router using orbilogin.com?
Thank you for your patience,
ChristineT
titaniumrx8
Sep 14, 2021Apprentice
After not having any responses on my open case from support for over 2 weeks, today I received the NDA to download the Beta 4.6.3.16
Not sure if it's worth installing if Netgear is going to push an automatic update which differs from the Beta any day now.
I've actually been pretty stable on 4.6.3.7 although it's annoying that AX mode is disabled to get the satellites working. I'll actually need to manually capture a lot of my settings if updating requires the factory reset that's going to wipe out my config. As a side note, I believe that part of the reason why I have been stable is that I assigned reserved IP addresses for all of my devices which seemed to keep the connections even for the mobile devices as they moved out of range and into another satellite range.
First thing that I'll be testing is AX mode since that's what my support case was mostly about.
- BerryvlSep 15, 2021Star
I have upgraded to the Beta and did not perform a factory reset at all.
After the upgrade the system was not stable either with AX features enabled or disabled.
Then i unchecked the option for 20/40MHz Coexistence and with AX Features enabled the system is completely stable for almost 2 weeks now. (Finally feels like i have my old Orbi back:smileyvery-happy:)
If my system would still be unstable today after upgrading I would have performed a factory reset but for the moment I follow the "if it aint broke, don't fix it" principle.
