Jul 12, 2021Guru - Experienced User
New - RBK752/753 Firmware Version 4.6.3.7 Released
Security Fixes: Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. New Features and Enhancements: Supports Smart...
- Sep 13, 2021
***Updated: 9/13/2021 11:50 AM PT
Hello Orbi Community,
Please accept my apologies for any delay in getting this message to you. I have been advised that an official firmware release is in the final stages of internal testing and in the process of being posted to our support site. Likely, within the next 24 hours.
To get this firmware release now please click the link below:
For instructions on how to manually download this firmware please visit:
How do I manually upgrade firmware on my Orbi router using orbilogin.com?
Thank you for your patience,
ChristineT
jghman11
Sep 19, 2021Aspirant
FW troubles. I have read so many post and tried every suggestion I can, but still have RBS750 not connecting since 4.6.3.7 and now 4.6.3.16 FW auto updates. When RBS750 powered up the white light blinks and "backhaul, guest, and whc-F12E15" shows up, on available wifi networks. I have reset, tried to connect hardwire locally, complete system reset to factory defaults and no success. I have router up and 1 satellite connected and somewhat working. Is there a definitive solution to this problem? BTW-I tried NG support and was left angry and wondering why I paid for this $400 system. Worked great for 9 months. Like the majority of posts on this I have read, I am frustrated. Any help is appreciated.
- FURRYe38Sep 19, 2021Guru - Experienced User
You can downgrade back to v3 if you want to try this:
- ahswpSep 20, 2021Apprentice
Netgear pushed the Beta to my 753s. Unfortunately, the push only went to my 750R not to my 2 753s. I manually upgraded the satalites and then turned the settings back to 100% for the 2.4 and other changes that had improved the problem.
I am STILL GETTING DISCONNECTS - the FIRMWARE DID NOTHING.
I continue to have issues with the satalite disconnecting.
NETGEAR IS THE WORST.Maybe I should return these to Costco like so many others have.
Whats the point of pushing a firmware that doesn't go to the satalites AND also still has the same problem?- FURRYe38Sep 20, 2021Guru - Experienced User
Has a factory reset and setup from scratch been performed since last update?
