Jul 13, 2021Guru - Experienced User
New - RBK752/753 Firmware Version 4.6.3.7 Released
Security Fixes: Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. New Features and Enhancements: Supports Smart...
- Sep 13, 2021
***Updated: 9/13/2021 11:50 AM PT
Hello Orbi Community,
Please accept my apologies for any delay in getting this message to you. I have been advised that an official firmware release is in the final stages of internal testing and in the process of being posted to our support site. Likely, within the next 24 hours.
To get this firmware release now please click the link below:
For instructions on how to manually download this firmware please visit:
How do I manually upgrade firmware on my Orbi router using orbilogin.com?
Thank you for your patience,
ChristineT
Sep 20, 2021Guru - Experienced User
Has a factory reset and setup from scratch been performed since last update?
ahswp wrote:
Netgear pushed the Beta to my 753s. Unfortunately, the push only went to my 750R not to my 2 753s. I manually upgraded the satalites and then turned the settings back to 100% for the 2.4 and other changes that had improved the problem.
I am STILL GETTING DISCONNECTS - the FIRMWARE DID NOTHING.
I continue to have issues with the satalite disconnecting.
NETGEAR IS THE WORST.
Maybe I should return these to Costco like so many others have.
Whats the point of pushing a firmware that doesn't go to the satalites AND also still has the same problem?
ahswp
Sep 23, 2021Apprentice
YES, THAT DOES NOT FIX A BROKEN FIRMWARE THAT SHOULD NEVER HAVE BEEN PUSHED. NETGEAR STINKS!
- FURRYe38Sep 23, 2021Guru - Experienced User
You'll need to contact NG support and let them know what your experiencing.
Thank you.
- FURRYe38Oct 08, 2021Guru - Experienced User
Return it to the seller then. eBay is not a authorized seller so warranties are not valid thru fleabay.
Or try the new FW thats just been released:- FURRYe38Oct 08, 2021Guru - Experienced User
Then try the new FW update.
Good Luck
- Gatorade2000Oct 08, 2021ApprenticeNG doesn't know where you got your device from. It automatically registers on first configuration. your device may have been a replacement device
Also NG doesn't warranty 2nd hand systems. Only NEW products from authorized sellers.
Users need to check MFr warranty before buying anything to ensure they understand what they are getting and what warranties are being covered.
