Jul 12, 2021Guru - Experienced User
New - RBK752/753 Firmware Version 4.6.3.7 Released
Security Fixes: Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. New Features and Enhancements: Supports Smart...
- Sep 13, 2021
***Updated: 9/13/2021 11:50 AM PT
Hello Orbi Community,
Please accept my apologies for any delay in getting this message to you. I have been advised that an official firmware release is in the final stages of internal testing and in the process of being posted to our support site. Likely, within the next 24 hours.
To get this firmware release now please click the link below:
For instructions on how to manually download this firmware please visit:
How do I manually upgrade firmware on my Orbi router using orbilogin.com?
Thank you for your patience,
ChristineT
ahswp
Sep 22, 2021Apprentice
YES, THAT DOES NOT FIX A BROKEN FIRMWARE THAT SHOULD NEVER HAVE BEEN PUSHED. NETGEAR STINKS!
Sep 23, 2021Guru - Experienced User
You'll need to contact NG support and let them know what your experiencing.
Thank you.
- FURRYe38Oct 08, 2021Guru - Experienced User
Return it to the seller then. eBay is not a authorized seller so warranties are not valid thru fleabay.
Or try the new FW thats just been released:- FURRYe38Oct 08, 2021Guru - Experienced User
Then try the new FW update.
Good Luck - tak1313Oct 08, 2021Luminary
sderc wrote:EBAY AND ANY SELLER/STORE HAS 30 DAYS RETURN POLICY
I SEE YOU'RE TRY TO BE A SMARTA** CALL EBAY AS FLEABAY WHEN YOU KNOW DAMM SURE IT'S NG SCREW UP AND OWN UP TO IT. IT EASY FOR YOU TO SAID/BE A SMARTA** BUT FOR ME PAID $360 FOR A PRODUCT USE FOR 2 MONTHS IS NOT.
THAT $360 = 3 FULL WORKING FOR ME.
I buy a LOT from fleabay. When I do, unless it's a recognized authorized seller, I know full well that ANY risk is on my dime. It's up to the buyer to assure the seller is an authorized dealer if he/she wants ANY type of support from the manufacturer. I take such risks willingly if the deal is there.
Such risks (that I have taken on) INCLUDE any f-up that a firmware update may cause. Has it happened? Yes. I just find ways to deal/fix it on my own.
The information you need to at least temporarily resolve your situation on your own is in this forum (and some even being in this thread).
- Gatorade2000Oct 08, 2021Apprentice
Thank you and take your rant somehwere else.
- Gatorade2000Oct 08, 2021ApprenticeNG doesn't know where you got your device from. It automatically registers on first configuration. your device may have been a replacement device
Also NG doesn't warranty 2nd hand systems. Only NEW products from authorized sellers.
Users need to check MFr warranty before buying anything to ensure they understand what they are getting and what warranties are being covered.- FURRYe38Oct 08, 2021Guru - Experienced User
Try the new FW update.
Good Luck
