Jan 14, 2022Guru - Experienced User
New - RBKE9 Series - RBRE960 / RBSE960 Firmware Version 6.0.3.85
New Features:
The IoT SSID is enabled by default after a factory reset.
DHCP Option 60 and 61 configurations are now supported in EU SKUs.
Security Fixes:
Fixes security vulnerabilities...
owlyn
Jan 14, 2022Luminary
I looked at the security page, and PSV-2021-0196 does not show.
Thanks for that fine. I'll have NG review that.
- FURRYe38Jan 14, 2022Guru - Experienced User
Installed this today.
Powered OFF RBR and RBS for a minute then back ON. No factory reset.Manual channel 11 and 48 and 69(6Ghz). CTS 64.
RBS are wireless connected.
This version fixes a bug I found back on .68. Ethernet backhaul RBS if powered OFF then back ON, causes wireless devices fail to connect to any RBS thats ethernet connected. This is now fixed on v85.
Will let this run and monitor this.
- owlynJan 15, 2022LuminaryI also installed.85 today. Did the satellites first, then the router. Although I had both satellites checked off, it only did one, so I had to run it again. Then I did the router. Only one satellite connected, so I powered that satellite down and back up, and had to do a manual connect. Everything has been fine so far.
- FURRYe38Jan 16, 2022Guru - Experienced User
Just curious, are you updating FW to the RBS using the RBRs web page or directly on the RBS web page?
