Jan 14, 2022Guru - Experienced User
New - RBKE9 Series - RBRE960 / RBSE960 Firmware Version 6.0.3.85
New Features:
The IoT SSID is enabled by default after a factory reset.
DHCP Option 60 and 61 configurations are now supported in EU SKUs.
Security Fixes:
Fixes security vulnerabilities...
sethm1
Mar 19, 2022Guide
Is this a beta version?
- DodgeDeBouletMar 19, 2022Apprentice
It's the version that installed automatically when I set my new RBKE9 router and satellites up 2 weeks ago. That generally doesn't happen with beta versions.
- Mikey94025Mar 19, 2022Hero
sethm1 wrote:Is this a beta version?
No, 6.0.3.85 is the latest official firmware version listed on Netgear's downloads site for the RBKE963: https://www.netgear.com/support/download/?model=RBKE963
- sethm1Mar 20, 2022Guide
thx. Trying to judge when the series 7 newest firmware is released. If 9 was in January and 8 was March 4th. Does this mean 7 (which is what I need) not till June? !
Hell, I hope not!- FURRYe38Mar 20, 2022Guru - Experienced User
NG doesn't give us info if or when new FW is forth coming. I try to keep forums updated when I see FW released. Just keep an eye on NGs download site or here in the forums.
THank you.
