Jan 14, 2022Guru - Experienced User
New - RBKE9 Series - RBRE960 / RBSE960 Firmware Version 6.0.3.85
New Features:
The IoT SSID is enabled by default after a factory reset.
DHCP Option 60 and 61 configurations are now supported in EU SKUs.
Security Fixes:
Fixes security vulnerabilities...
brianld
May 26, 2022Apprentice
I'm a big advocate of "If it isn't broke, don't fix it", but actually a bit surprised that we haven't seen any firmware update for these in several months.
- FURRYe38May 26, 2022Guru - Experienced User
That's probably a good thing. Hasn't been a ton of users posting about bad things.
- DodgeDeBouletMay 26, 2022Apprentice
Which doesn't mean there aren't bad things.
I still can't get an iPad 2 to connect (works fine off an ancient WNDR4500), and a variety of devices drop off the network every 2 weeks or so. Mostly IoT stuff; smart switches, webcams and appliances. Reboot the router, and everything reconnects.
For about 2 weeks ...
NetGear appears to be stumped.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡What channels are you using? Auto?
What is the Transmit power level set to and what is the CTS value your using on the RBR.
