Blanca_O
Oct 27, 2022NETGEAR Employee Retired
New - RBRE960 / RBSE960 Firmware Version 6.3.7.5 Released
Enhancements:
Improve the stability between base and satellite connections.
Improves satellite firmware upgrade stability.
Improves satellite ...
AllanSor
Oct 27, 2022Tutor
Saw this new update and found my RBKE963 in hopes to start using it after this update. My old RBK53 is still running solid, but looking forward to get the 963 up and running.
Online update says “No New Firmware Available” for RBRE960 and for RBSE960 stats “ Service unreachable”
Downloaded and unpacked the files. Try to manual update RBSE using RBSE960-V6.3.7.5.chk I get a message “Firmware upgrade failed. Please check your file.”
Did try Edge, Firefox and Chrome on a fresh installed Windows 10, no antivirus or security soft installed. Wired network.
Did anyone update successfully using the files from the link?
- ian340Oct 28, 2022Tutor
Just in case it helps, I had the exact same problem with one of my two RBSE960 satellites. I also found the only option available was to manually upgrade.
The upgrade worked fine on the first satellite (with wireless backhaul) but not on the second (with ethernet cable backhaul). I powered the problematic satellite off and on and then the upgrade worked ok. I then upgraded the router without issue.
So far, no problems noted with the new firmware.
- guidro76Oct 28, 2022Aspirant
I recently had the same problem as prescribed by other members . I wish netgear would bring more of a solid firmware update and notes because the customer might re push the same firmware thinking its a problem with device .. to turn in for repair.
