Blanca_O
Oct 27, 2022NETGEAR Employee Retired
New - RBRE960 / RBSE960 Firmware Version 6.3.7.5 Released
Enhancements:
Improve the stability between base and satellite connections.
Improves satellite firmware upgrade stability.
Improves satellite ...
pkgadd
Nov 03, 2022Luminary
The update itself worked fine (satellites first, router last, no factory reset), but I notice a weird regression with this version.
The RBKE963 mesh system is configured in AP mode, as stations of another router and I've given router and both satellites (internal-) DNS (A) records to access them more comfortably than having to remember their IP addresses. This worked fine with 6.0.3.85 and continues to work with 6.3.7.5 for the satellites, but the router only answers to its domain name with "500 Internal Server Error" (I can access the web interface via its IP address just fine).
router (affected):
http://172.21.253.36/ <-- works fine
http://rbre960/ (relying on the configured search domain) <-- 500 Internal Server Error
http://rbre960.fully.qualified.domain.example.com/ <-- 500 Internal Server Error
satellites (fine):
http://172.21.253.37/, http://rbse960-oben/, http://rbse960-oben.fully.qualified.domain.example.com/ <-- works fine
http://172.21.253.38/, http://rbse960-unten/, http://rbse960-unten.fully.qualified.domain.example.com/ <-- works fine
The name resolution works just fine, I can ping rbre960 and rbre960.fully.qualified.domain.example.com without any problem, it's just the webinterface that doesn't like being accessed by its externally configured domain name.
> nslookup rbre960
Server: router.fully.qualified.domain.example.com
Address: fd01:xxxx:xxxx:xxxx::1
Address: 172.21.253.36
> ping rbre960
Ping wird ausgeführt für rbre960.fully.qualified.domain.example.com [172.21.253.36] mit 32 Bytes Daten:
Antwort von 172.21.253.36: Bytes=32 Zeit<1ms TTL=64
Ping-Statistik für 172.21.253.36:
Pakete: Gesendet = 4, Empfangen = 4, Verloren = 0
(0% Verlust),
Ca. Zeitangaben in Millisek.:
Minimum = 0ms, Maximum = 0ms, Mittelwert = 0ms
(configured lan network, 172.20.0.0/14)
This worked fine in the previous version and is reproducible in the current versions of firefox, chrome and edge (including incognito mode of either of them).
- FURRYe38Nov 11, 2022Guru - Experienced User
Going on 10 days of good uptime on the 9 series in AP mode thats connected to a XR1000 router and a CAX80 modem:
RBS are ethernet connected to the RBR using 2.5Gb ports with XS505M and GS110MX in between them.
- PaiatzNov 17, 2022Guide
Just downloaded several times the new FW. https://www.downloads.netgear.com/files/GDC/RBKE963/RBRE960-V6.3.7.5.zip and it'll show as a .chk file after i extracted it properly. (windows might not interpret it correctly). A manual upload of such a *.chk file doesn´t work
Any suggestions ?
regards
Raimar
- FURRYe38Nov 18, 2022Guru - Experienced User
The unpacked file is supposed to be .chk
Any suggestions ?
regards
Raimar
