Blanca_O
Oct 27, 2022NETGEAR Employee Retired
New - RBRE960 / RBSE960 Firmware Version 6.3.7.5 Released
Enhancements:
Improve the stability between base and satellite connections.
Improves satellite firmware upgrade stability.
Improves satellite ...
Nov 11, 2022Guru - Experienced User
Going on 10 days of good uptime on the 9 series in AP mode thats connected to a XR1000 router and a CAX80 modem:
RBS are ethernet connected to the RBR using 2.5Gb ports with XS505M and GS110MX in between them.
- PaiatzNov 17, 2022Guide
Just downloaded several times the new FW. https://www.downloads.netgear.com/files/GDC/RBKE963/RBRE960-V6.3.7.5.zip and it'll show as a .chk file after i extracted it properly. (windows might not interpret it correctly). A manual upload of such a *.chk file doesn´t work
Any suggestions ?
regards
Raimar
- FURRYe38Nov 18, 2022Guru - Experienced User
The unpacked file is supposed to be .chk
Any suggestions ?
regards
Raimar
