Blanca_O
Oct 27, 2022NETGEAR Employee Retired
New - RBRE960 / RBSE960 Firmware Version 6.3.7.5 Released
Enhancements:
Improve the stability between base and satellite connections.
Improves satellite firmware upgrade stability.
Improves satellite ...
DisneyFanatic4
Nov 20, 2022Tutor
Did anyone notice that after a factory reset on this firmware version, the default 5ghz channel is now 40 by default? The previous default used to be 48. Any reason why Netgear would change this?
Nov 21, 2022Guru - Experienced User
I was told a long time about in Orbi 8 series days that NG found channel 40 worked best. Something I've been using since and haven't had any problems. They seem to recommend not using channel 36, I can't remember the details but they recommended avoiding 36, only used as last resort kind of thing. 44 and 48 are still good channels that can be used if 36 and 40 are congested or as a troubleshooting step.
- DisneyFanatic4Nov 23, 2022Tutor
Thanks, FURRYe38, for the additional information! I'll keep it on 40 as suggested.
- FURRYe38Nov 25, 2022Guru - Experienced User
16 Days online while in AP mode:
2.5Gb ports used for ethernet connected RBS. CAT6A STP cabling for these ports.
Working great. - FURRYe38Dec 06, 2022Guru - Experienced User
FYI, new FW is available:
