Sep 08, 2023Guru - Experienced User
New - RBRE960 / RBSE960 Firmware Version 7.2.6.21 Released
Enhancements: 09/08/2023
Improves the stability of connections between router and satellites
Improves satellite firmware upgrade stability
Security Fixes:
This firmware addresses securi...
- Sep 09, 2023
I manually updated 2 x RBSE960 satellites and then the RBRE960 router to 7.2.6.21 via the webpage (Safari browser on a Mac) as directed in the user manual. All appears to have worked fine although I haven't spotted any changes in function.
This went much more smoothly than my last manual update to 6.3.7.10 when I needed to do factory resets of the entire system to get it to work.
Retired_Member
Sep 22, 2023I did the firmware update, and all went intially well, except two out of my 4 satellites keeps disconnecting.
Its always the same ones, I also did a factory reset on the router and all the satellites, and still the same two satallites keep disconnecting.
I have to keep rebooting the entire system to get them backup and running.
Any suggestions?
- FURRYe38Sep 22, 2023Guru - Experienced User
I'd turn OFF the working RBS and move the other two RBS into place where the working RBS are and see if the problem follows.
What is the distance between the router and 📡 satellite(s)?
Any suggestions?
