Sep 08, 2023Guru - Experienced User
New - RBRE960 / RBSE960 Firmware Version 7.2.6.21 Released
Enhancements: 09/08/2023
Improves the stability of connections between router and satellites
Improves satellite firmware upgrade stability
Security Fixes:
This firmware addresses securi...
- Sep 09, 2023
I manually updated 2 x RBSE960 satellites and then the RBRE960 router to 7.2.6.21 via the webpage (Safari browser on a Mac) as directed in the user manual. All appears to have worked fine although I haven't spotted any changes in function.
This went much more smoothly than my last manual update to 6.3.7.10 when I needed to do factory resets of the entire system to get it to work.
gringo28
Sep 26, 2023Aspirant
7.2.6.21 update was smooth & network is stable. Old firmware was causing devices & network to drop several times per day, so this update is solid. Parental Controls, however, have stopped working. Anybody else experiencing this? I actually think they may have stopped working BEFORE the update yesterday. Thanks
Sep 26, 2023Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
If SPC is having problems, I'd submit a bug report:
