Sep 08, 2023Guru - Experienced User
New - RBRE960 / RBSE960 Firmware Version 7.2.6.21 Released
Enhancements: 09/08/2023
Improves the stability of connections between router and satellites
Improves satellite firmware upgrade stability
Security Fixes:
This firmware addresses securi...
- Sep 09, 2023
I manually updated 2 x RBSE960 satellites and then the RBRE960 router to 7.2.6.21 via the webpage (Safari browser on a Mac) as directed in the user manual. All appears to have worked fine although I haven't spotted any changes in function.
This went much more smoothly than my last manual update to 6.3.7.10 when I needed to do factory resets of the entire system to get it to work.
Sep 26, 2023Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
If SPC is having problems, I'd submit a bug report:
gringo28 wrote:
7.2.6.21 update was smooth & network is stable. Old firmware was causing devices & network to drop several times per day, so this update is solid. Parental Controls, however, have stopped working. Anybody else experiencing this? I actually think they may have stopped working BEFORE the update yesterday. Thanks
gringo28
Sep 26, 2023Aspirant
Thank you! Yes, I just did that reboot sequence this morning. No issues accessing SPC via the app and I've toggled the service on/off from the app as well. All devices are visible on the network. I strongly suspect the SPC service stopped working Sunday AM; before I upgraded to 7.2.6.21. Tbh, am just glad that the firmware update has made the network very stable. Thx for your help!
- FURRYe38Sep 26, 2023Guru - Experienced User
Enjoy. 📡 - FURRYe38Sep 26, 2023Guru - Experienced User
For any continued SPC issues, please post here if you need too:
https://community.netgear.com/t5/NETGEAR-Smart-Home-Parental/bd-p/en-home-smart-parental-controls
Good Luck.
- Mikey94025Oct 04, 2023Hero
I notice that the RBKE963 downloads page has removed the 7.2.6.21 firmware for the RBRE960 router: https://www.netgear.com/support/product/rbke963b#download. It now lists 6.3.7.10.
The RBSE960 satellite download link is still for 7.2.6.21.
Is the 7.2.6.21 firmware being recalled?
- FURRYe38Oct 04, 2023Guru - Experienced User
Though initial link is still seen under Top Support Articles. But it only shows the RBS as well. Will check on this.
