Sep 08, 2023Guru - Experienced User
New - RBRE960 / RBSE960 Firmware Version 7.2.6.21 Released
Enhancements: 09/08/2023
Improves the stability of connections between router and satellites
Improves satellite firmware upgrade stability
Security Fixes:
This firmware addresses securi...
- Sep 09, 2023
I manually updated 2 x RBSE960 satellites and then the RBRE960 router to 7.2.6.21 via the webpage (Safari browser on a Mac) as directed in the user manual. All appears to have worked fine although I haven't spotted any changes in function.
This went much more smoothly than my last manual update to 6.3.7.10 when I needed to do factory resets of the entire system to get it to work.
Oct 04, 2023Guru - Experienced User
NG has pulled the RBR FW due to some regional issue in the FW that NG is currently investigating. I don't think this is a operational issue that effects normal system operation. USA region isn't effected. I'll post if and when I know more.
Oct 05, 2023Guru - Experienced User
Ok, v.21 RBR FW will get reposted soon. There is a EU regulatory regional issue with this version of FW. NG will be putting forth a follow on FW version that resolves this EU regulatory regional issue soon. This only effects the EU region.
Orbi 960 series users located in the EU Region will be directed to update there 960 series systems to the follow on FW version when it becomes available.
All other regions can continue to use v.21.
- LLeroyFeb 23, 2024Tutor
When do you think the update will be available in EU ?
