Sep 08, 2023Guru - Experienced User
New - RBRE960 / RBSE960 Firmware Version 7.2.6.21 Released
Enhancements: 09/08/2023
Improves the stability of connections between router and satellites
Improves satellite firmware upgrade stability
Security Fixes:
This firmware addresses securi...
- Sep 09, 2023
I manually updated 2 x RBSE960 satellites and then the RBRE960 router to 7.2.6.21 via the webpage (Safari browser on a Mac) as directed in the user manual. All appears to have worked fine although I haven't spotted any changes in function.
This went much more smoothly than my last manual update to 6.3.7.10 when I needed to do factory resets of the entire system to get it to work.
gumpgump
Oct 17, 2023Guide
I updated my Orbi RBRE960 today with this firmware, no troubles. I have only a router.
I hadn't realized there was a new release of the firmware -- my regular checks say nothing is available, then a search found this. I wonder, would it be reasonable for Netgear to have an announce-type mailing list that tells us about new releases?
Anyhow, thanks for the post.
- FURRYe38Oct 17, 2023Guru - Experienced User
Enjoy. 📡- pnoskerOct 27, 2023TutorNot sure what happened with this firmware but my wired backhaul stability has gotten terrible. Oddly, switching the RBS to wireless has improved things substantially. Anyone else with a similar issue?
- FURRYe38Oct 27, 2023Guru - Experienced User
How are the RBS connected to the RBR when ethernet connected?
Any LAN switches or patch panels in the mix?
What CAT# lan cable are you using between the RBR and RBS?
Are you using the 2.5Gb LAN ports in back of the RBS or the 1Gb LAN ports to connect the RBS to the RBR?
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️What channel configurations are currently set on the router?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
