Sep 08, 2023Guru - Experienced User
New - RBRE960 / RBSE960 Firmware Version 7.2.6.21 Released
Enhancements: 09/08/2023
Improves the stability of connections between router and satellites
Improves satellite firmware upgrade stability
Security Fixes:
This firmware addresses securi...
- Sep 09, 2023
I manually updated 2 x RBSE960 satellites and then the RBRE960 router to 7.2.6.21 via the webpage (Safari browser on a Mac) as directed in the user manual. All appears to have worked fine although I haven't spotted any changes in function.
This went much more smoothly than my last manual update to 6.3.7.10 when I needed to do factory resets of the entire system to get it to work.
gumpgump
Oct 17, 2023Guide
I updated my Orbi RBRE960 today with this firmware, no troubles. I have only a router.
I hadn't realized there was a new release of the firmware -- my regular checks say nothing is available, then a search found this. I wonder, would it be reasonable for Netgear to have an announce-type mailing list that tells us about new releases?
Anyhow, thanks for the post.
Oct 17, 2023Guru - Experienced User
Enjoy. 📡
