Mar 22, 2024Guru - Experienced User
New - RBRE960 / RBSE960 Firmware Version 7.2.6.31 Released
Enhancements: 03/22/2024
(For all regions except Europe)
Improves the stability of WiFi device connections during roaming
This firmware addresses security vulnerabilities. For more informatio...
- Jun 14, 2024
I have noticed issues that only seem to crop up after days of running - as few as 3-4 days, as many as 22 days. They are router or satellite restarts, memory growth in satellites to the point of causing a reboot and disconnect of all devices. I have seen WiFi disconnect and stop working until the router was rebooted. Have seen IPv6 stop working until it was re-enabled (likely a Comcast-NG interaction issue). I have seen satellites lose their backhaul connection with the router.
I believe at least the memory creep issues are related to using 2 satellites on Ethernet backhaul, just a guess. It could also be related to higher speed networks, mine is a 2G/200MB service. Maybe it's a combination of different factors that make the perfect storm that problems can appear? The % of Netgear customers with 2G and multiple Ethernet-wired backhaul satellites is small, I suspect. Plus, if there are some bugs that pop up after a number of days of running, NG has said that this kind of testing is very hard for them to do.
I just went back to v.21 to see how it runs. If v.31 is working well, great - if not, some caution could be warranted to try V.21 before spending lots of time trying to find a problem.
owlyn
Mar 25, 2024Luminary
Updated my two satellites and then the router. No problems. Found that it changed my IPv6 DNS settings to get from the ISP rather than the ones I manually entered previously. Changed those back to the manual settings (to what the ISP uses!) , and discovered IPv6 DNS doesn’t work with Armor Web Protection turned on. Turned it off and no problems.
bullm00n
Jun 14, 2024Virtuoso
Ah - I wonder if this why my manually set DNS caused problems. I have Armor on as well. When I have some time, I will try it again with Armor off. For curiosity only though - IPV6 with the DHCP'd Comcast DNS still fine here.
- Retired_MemberJun 15, 2024
Unfortunately I randomly started having satellites disconnecting, so I had to downgrade back to "Firmware Version 6.3.7.10", since I am in the EU region.
Since I don’t have time to keep troubleshooting the issue, I am going to stay on the older firmware until Netgear iron out the bugs.- FURRYe38Jun 15, 2024Guru - Experienced User
Thank you for letting us know.
- RafSJul 06, 2024Apprentice
I’ve been running firmware 6.3.7.5 for the longest time and tried all the firmware that followed with issues on each one. I uploaded the newest ones three weeks ago and had it run for 3 weeks and it was nothing but issues. First of all, it would not record all the devices that were hardwired to the satellites, something I had an issue with on previous firmwares and had netgear involved without a resolution. Second, the connection between satellites was horrible, and it would drop satellite connection constantly with the satellites always being in the same exact location as they’ve been since I set up the system. I finally went back to 6.3.7.5 today (July 6th) and everything is working great. The connection to the satellites was flawless and all my devices are listed in the device list as they should be, no matter what brand of device they are. Not sure what Netgear is doing, but they are not moving in the right direction. Go back to 6.3.7.5 and improve from that.
