Dec 06, 2022Guru - Experienced User
New - RBRE960 / RBSE960 Firmware Version v6.3.7.10 Released
New Features: 12/05/2022
[Asia SKU only] Supports the Japan IPv6 plus feature.
[Asia SKU only] Supports the HK PCCW IPTV feature.
Security Fixes:
Addresses security vulnerabilities...
pkgadd
Dec 08, 2022Luminary
The previously reported "500 Internal Server Error" when accessing the webinterface from a(n externally defined) DNS name remains in this version (I need to access it by its IP, which works).
- FURRYe38Dec 10, 2022Guru - Experienced User
So got my RBKE963 loaded today. Did a power cycle after the FW loaded then Factory reset everything. Instead of setting up from scratch, I loaded the saved configuration from backup file from last version of FW that was loaded.
DCHP IP address pool set to .100 to .150 for my needs.
Manual channel 11 and 48 and 69.
SIP ALG enabled.
RBS wirelessly connected.
25% power as I already have a 8 series Orbi running for the main home network.
40Mhz co-existance only.
So here is a first to date ever seeing 4800Mpbs connection rate between two devices. đČ
RAXE500 in wireless bridge mode connected to the RBKE960 on 6Ghz:
Intel AX210 6Ghz wireless PC connected:
