Dec 06, 2022Guru - Experienced User
New - RBRE960 / RBSE960 Firmware Version v6.3.7.10 Released
New Features: 12/05/2022
[Asia SKU only] Supports the Japan IPv6 plus feature.
[Asia SKU only] Supports the HK PCCW IPTV feature.
Security Fixes:
Addresses security vulnerabilities...
VFD2
Dec 13, 2022Tutor
I updated manually, but the system still thinks the old firmware is the new firmware.
Dec 13, 2022Guru - Experienced User
Ignore it.
I recommend disabling Auto Update feature on the RBR anyways.
- Dfran1Dec 18, 2022ApprenticeOk
I finally factory reset yesterday morning with this firmware and set up from scratch. I also did the shut down , all acording to Furrye38 to a tee.
I get 1080Mbps on my iPhone now, WOW never ever seen that before !!
But …..
Now I go to use the Orbi app and by web browser
I can not see any devices attached ??
the web browser shows nothing attached, not even the satellite’s
The app just keeps spinning when I go to either
Device manager or network map.
Is this a bug ?
Everything is still working great , and can not reboot router till latter.
Edit:
Just a note: all was great before the factory default BUT I could never get a connection that hight. Ran for a week without this issue at all.
2nd edit: the app and browser worked fine all up till this just over 24 hours.- FURRYe38Dec 19, 2022Guru - Experienced User
Bugs in Orbi app and Anywhere Access.
I've seen no issues with the web browser showing my devices...
If you have Orbi app issues, please post here:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
or submit a bug report thru Orbi app:
- Dfran1Dec 19, 2022ApprenticeAccess control got turned on somehow. I know I did not purposely turn it on, weird……
I turned it off, rebooted and still working great.
Not that I think turning on access control should kill the device list showing ???
