Dec 06, 2022Guru - Experienced User
New - RBRE960 / RBSE960 Firmware Version v6.3.7.10 Released
New Features: 12/05/2022
[Asia SKU only] Supports the Japan IPv6 plus feature.
[Asia SKU only] Supports the HK PCCW IPTV feature.
Security Fixes:
Addresses security vulnerabilities...
Dec 13, 2022Guru - Experienced User
Ignore it.
I recommend disabling Auto Update feature on the RBR anyways.
Dfran1
Dec 18, 2022Apprentice
Ok
I finally factory reset yesterday morning with this firmware and set up from scratch. I also did the shut down , all acording to Furrye38 to a tee.
I get 1080Mbps on my iPhone now, WOW never ever seen that before !!
But …..
Now I go to use the Orbi app and by web browser
I can not see any devices attached ??
the web browser shows nothing attached, not even the satellite’s
The app just keeps spinning when I go to either
Device manager or network map.
Is this a bug ?
Everything is still working great , and can not reboot router till latter.
Edit:
Just a note: all was great before the factory default BUT I could never get a connection that hight. Ran for a week without this issue at all.
2nd edit: the app and browser worked fine all up till this just over 24 hours.
But …..
Is this a bug ?
Edit:
- FURRYe38Dec 19, 2022Guru - Experienced User
Bugs in Orbi app and Anywhere Access.
I've seen no issues with the web browser showing my devices...
If you have Orbi app issues, please post here:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
or submit a bug report thru Orbi app:
- Dfran1Dec 20, 2022ApprenticeAccess control got turned on somehow. I know I did not purposely turn it on, weird……
I turned it off, rebooted and still working great.
Not that I think turning on access control should kill the device list showing ???- FURRYe38Dec 21, 2022Guru - Experienced User
How did you disable Access Controls? Web page or Orbi app?
Wondering if you can repeat it again then see if disabling it again returns it back to working order?
