las2305
Aug 15, 2022Aspirant
new AX4200 does not connect with previous satellites
Please help. I had an Orbi AX4200 WiFi 6 High-Performance Router (RBR750) with two satellites that worked fine from Nov '21 to June '22. The router crapped out and I could not purchase another rout...
Aug 15, 2022Guru - Experienced User
What FW version is ON the RBR and do you know what FW version is on the RBS? Sounds like the FW is not the same on the RBR as whats on the RBS. They all need to be at the same version level of FW.
Can you connect the RBS via ethernet and see if they show up with an IP address that you can use to access the RBS web page?
