JtootheJ
Feb 26, 2020Follower
New house build- Network set up
I am in the process of building a house and will be setting up a AX6000 Wifi 6 network. I have several POE camera's and a POE Ring Doorbell. The entire house is wired for ethernet and all of the et...
Feb 26, 2020Guru - Experienced User
Orbi AX doesn't support any PoE out the back end. Recommended switches are non managed and non green ethernet featured switches if they are needing to be connected between the RBR and RBS. Green ethernet seems to cause problems for Orbi systems. Managed switches can work however ensure ALL IGMP protocols are disabled on any managed switch if used between the RBR and RBS. I presume any switches with out the RBS on the segment would work for your needs. NG has switch products available. I use HP ProCure and some D-Link switches.
You might post about this in NGs Switch forum to see what would be recommended for any PoE configurations.
