Ozzie1982
Mar 14, 2020Aspirant
New Orbi RBK852 connects to internet, but has no sound in system. How do I get it to work?
NETGEAR ORBI WIFI 6 Tri-Band Mesh System - AX6000, RBK852 (Router & Satellite) - new setup with Orbi App and latest firmware (RBS850-V3.2.9.2_1.2.4). Excellent connection speed but does not broadcast sound either with direct ethernet cable connection (orbi supplied) or via wireless. Does anyone know how to fix the problem?
- ekhalilMasterPlease post on the Orbi AX forum here: https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Can you please explain more what you mean with sound broadcast? Do you use a mesh sound system?- Ozzie1982Aspirant
As for the sound not broadcasting, I mean that I did not have sound coming from the computer which was directly connected to the ORBI ROUTER RBR850, and no sound coming from the Xbox, Roku, etc. that I had connected to the ORBI SATELLITE RBS850. I decided to disconnect the ethernet cable that came with the NETGEAR ORBI WIFI 6 Tri-Band Mesh System - AX6000, RBK852 and utilized the CAT 5e cable that was attached to my original Router that I was replacing (CAT 5e running from Spectrum modem to ORBI ROUTER RBR850). I then rebooted the Spectrum modem and the ORBI RBK852 system. With those two changes, I then had sound coming to all of my devices. It has now been approximately 10 hours and the system seems to be working however Yahoo web pages are not loading too well with this new network. More testing to be done.
- ekhalilMaster
Do you have Technicolor C2000T ISP Router?
If yes, then please note that this is box has a router functionality. Your Orbi seems to be set in Router Mode, which causes such issues since you are having two routers in the network.
You have two option:
1. Change the technicolor to transparent bridged mode using these instructions: https://www.centurylink.com/home/help/internet/modems-and-routers/technicolor-c2000t/advanced-setup/... or call Centurylink support to get help with this.
2. Change Orbi to AP Mode using the web GUI (orbilogin.com) and selecting ADVANCED >> Advanced Setup >> Router/AP Mode.
