Batt11
Dec 16, 2020Tutor
New Orbi RBR750 - multiple issues
We just purchased a new Orbi BRB750 wifi-mesh system a few weeks ago. At first, it seemed great, there was no more complaining from the family about the poor wifi signal of my AT&T modem. Shortly aft...
Batt11
Dec 16, 2020Tutor
Sorry..
Firmware: V3.2.16.6_1.4.4
House Modem: AT&T Pace 5268c (1Gb fiber)
vajim
Dec 16, 2020Master
Batt11 wrote:Sorry..
Looks like that modem has wifi built in. IF that's the case and you want to run the Orbi you're going to need to set one of them to the AP (Access Point) mode. You can't run 2 routers in the same network as in router mode.
You may want to post your question in the Orbi AX section.
- Batt11Dec 16, 2020Tutor
The modem does not have a bridge mode, so (originally) the wifi was turned off, only the orbi was plugged into the modem via ethernet and then set as the DMZ for that modem.
Do I have an Orbi AX?
- vajimDec 16, 2020Master
I posted over there, thanks!
https://community.netgear.com/t5/Orbi-AX/New-Orbi-RBR750-multiple-issues/m-p/2023372#M10486
