FormerPro
Apr 01, 2024Aspirant
New Orbi RBRE960 after loss of power
After a short power outage, I cannot logon to the router with my two Apple devices, ( iPhone 14 Pro Max and iPad Pro, both running latest OS). Prior to the power outage they connected. All other devi...
- Apr 02, 2024
On both devices, have you selected "Forget This Network".
Ensure Private IP Address is disabled.
I'd reboot the devices. Then try to reconnect.
What FW is on the RBR and RBS?
Are RBS wireless connected?
Distance in between the RBR and RBS?Home size in Sq feet please?
Turn OFF the RBS temporarily to see if the devices connect to the RBR alone?
FormerPro
Apr 02, 2024Aspirant
Thank you for your suggestions. I checked the advanced settings and it was already configured to allow new devices to connect. So I decided to "forget this network" using my iPhone and then "joining this network" and reentering the password and then I was able to connect. I then tried to "join" with the iPad and it connected with no problem.
This was obviously an IOS issue where the MAC ID didn't refresh after the power failure and reboot of the router. Why the iPad couldn't connect, is a mystery. I have notified Apple of the issue.
Thank you all for your help! I greatly appreciate it!
Apr 02, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
