jirkal
May 06, 2023Follower
New Orbi replacement? Easy or difficult?
Hi there. I have an older Orbi set up and was considering buying a new system for more efficiency (6 years old). Would replacing my old Orbi just be a matter of swapping units ? (Comcast modem in pla...
mrsimon007
May 07, 2023Aspirant
Replacing an Orbi system can be either easy or difficult depending on a few factors, such as the reason for the replacement, the type of Orbi system being used, and the level of technical expertise required.
