njweb
Apr 14, 2021Luminary
New RBK753S - Stability / wifi connection reliability issues every other day so far? (fw V3.2.16.22)
I recently upgraded to the Orbi AX / Wifi 6 RBK753S (from the AC3000 RBK53). I never had any real issues with my RBK53, but since my ISP plan speed just went up again, I wanted to maximize throughput...
- Apr 23, 2021
Something to try out, Disable AX mode on the RBR. Just the 5Ghz radio or both. Up to you.
Also set CTS values to 2347. Then retest the killer adapter.
Then maybe re-enabled AX both and re-test for consistency.
njweb
PS: (Since I cannot edit the original post anymore - outside time limit to edit it:
I just to clarify, overall it is workling very well. Just trying to avoid a disconnect / slowness issue every other day (even if only one occurence per day on which it occurs).
- FURRYe38Apr 14, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satelliteWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try disabling the following and see:
ArmorSet 20/40Mhz Coexistence to 40Mhz only. Under Advanced Tab/Advanced Settings/Wireless Settings
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
- vajimApr 14, 2021Master
my fav....What is the size of your home? Sq Ft?
IF your orbi is working I'd hold off on the firmware update. The recent track record is bad.
- njwebApr 14, 2021Luminary
vajim wrote:my fav....What is the size of your home? Sq Ft?
Thanks for the feedback!
Yes, aside from the two temporary issues noted in my OP above, it is working fine for all my devices.
In fact I am getting my ISP's full bandwidth in the room where router is located - I am on a "400 Mpbs" downstream plan, but getting about 450 Mbps via Orbi wifi which is what my ISP is actually provisioning...
With the RBK53 I was getting about 25% less with my prior Orbi router in the same position...
Just trying to avoid any disconnects, at least not a few times a week.
Replies inline below
FURRYe38 wrote:
njweb >> I am using my own modem - Motorola MB8600 DOCSIS 3.1 (same one I have been using for 2 1/2 years, including with my prior Orbi).
njweb >> Just under 3,100 without basement, close to 4,500 with finished basement
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellitenjwweb |>> Will have to measure, but basically the router is on main floor in corner room; one satellite is upstairs and other one is in basement (exact same positions as prior Orbi components - I placed them literally within 1/4 of an inch of prior Orbi router and satellite locations).
Any Wifi Neighbors near by? If so, how many?njweb reply >> channels using defaults, which are as follows:
2.4 GHz - Auto
5GHz - 48
Neighbors are spread out due to large lot sizes.
Same channels were used for prior Orbi and worked fine for the past 3 1/2 + years.
njweb >> Thanks, let me check out the link when I get a chance and, as suggested, I will also disable Armor on my RBK753S system since that is not something I had with my prior AC3000 Orbi...
Thanks a lot! (My responses are inline above as mentioned).
When you see this "disconnect" is this across both wired and wireless?
Is there any front LED indication on the RBR when this happens?
njweb wrote:PS: (Since I cannot edit the original post anymore - outside time limit to edit it:
- njwebApr 15, 2021Luminary
FURRYe38 wrote:When you see this "disconnect" is this across both wired and wireless?
Thanks!
Great question. Unfortunately I did not get a chance to check since I was focused primarily on getting back to work on both occasions - I quickly rebooted things to get back online...
If / when the connectivity / speed issue happens again, I will check other devices to confirm if it is just wireless and also check the Orbi's LED (which is not visible from where I am sitting since the Orbi router is located behind a monitor and also facing the opposite direction...
- FURRYe38Apr 15, 2021Guru - Experienced User
Well since you have new FW loaded, See what happens. A factory reset maybe needed as well.
