KevTN
Jun 22, 2021Aspirant
New RBK852 connection to security camera
Hello, Put in a RBK852 Saturday. Everything is working great except 2 of my 3 security cameras, ADT security them put in, are connecting to 5Ghz instead of 2.4Ghz. I have tried different channels...
Jun 22, 2021Guru - Experienced User
Is there a reason why there suppose to connect to 2.4Ghz instead of 5Ghz? 5Ghz performs and is faster than 2.4Ghz.
Try turning down the power on the 5ghz radio on the RBR...
KevTN
Jun 23, 2021Aspirant
At 5ghz it takes forever to load images and if at all. Connection and streaming is very slow.
- FURRYe38Jun 23, 2021Guru - Experienced User
Should be the opposite really.
What is the distance between the cameras and the RBR or RBS?
Also try turning down the power output of the RBRs 5Ghz wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
You'll need to reboot the cameras to see if they re-connect to 2.4Ghz signal.
- KevTNJun 24, 2021Aspirant
The distance is around 45 feet.
can I setup my old nighthawk in tandem with the Orbi? I know I can assign the 2.4 channel on it. That way each will have its own dedicated router...
- FURRYe38Jun 24, 2021Guru - Experienced User
Yes you can...
Does turning down the power on RBR do anything?
