Jan 13, 2020Guru - Experienced User
New RBK852/853 Firmware v3.2.9.2 Release
New Features and Enhancements: Supports connecting two satellites to the Orbi network Bug Fixes: The Orbi app was not able to show the guest client’s link rate if the Orbi was operating in AP m...
Chuck_M
Jan 14, 2020Mentor
Works just fine here on RBR and RBS. No glitches. Thanks for heads up FURRYe38 .
Chuck_M
Jan 15, 2020Mentor
I have found one odd piece of behavior with the new update.
On my system I have 1 x RBR850, 1 x RBS850 and 2 x RBS50s.
The RBS50s are hard wired. The RBS850 is RF Backhauled.
Since the update to this version, the RBS850 reports itself as hard wired even though it is not. It reports this in both the Web GUI as well as the App.
I have rebooted with no change to effect and checked it again after 12 hours -- still the same.
Anyone else see this behavior?
