Bloniarz
Mar 09, 2022Aspirant
New RBKE960 and RBSE960 dropping internet when connected to Xfinity router in bridge mode
I just purchased RBKE963 to replace ORBI850 that was not working. RBKE960 was working fine when in dual mode with xfinity CGM4331COM in dual router mode. As soon as I turned the BRIDGE MODE on th...
Mikey94025
Mar 09, 2022Hero
One more thought, what other options have you changed from the defaults that affects your upstream internet connection from Xfinity? For example, have you changed any of the WAN Setup options or Advanced...IPV6? IPV6 defaults to Disabled but I changed it to Auto Detect. If nothing else works you might try that just to see if it makes any difference.
Bloniarz
Mar 10, 2022Aspirant
Thank you for your reply. CTS is set to 2347 Domain server set use 8.8.8.8 and 8.8.4.4. Channel set Auto, 48,101. I have latest firmware. Domain and password personal settings Rest is set to factory original settings.
All works great in double router mode.
As soon as I turn on the bridge mode on the Xfinity router my interned starts dropping. Loose connection to all devices as well as the application message under the internet block under basic starts shifting from good, waiting to error/no internet.
- Mikey94025Mar 10, 2022Hero
As soon as I turn on the bridge mode on the Xfinity router my interned starts dropping. Loose connection to all devices as well as the application message under the internet block under basic starts shifting from good, waiting to error/no internet.I don't have any good ideas for why your Xfinity modem in bridge mode is causing these new issues for you. Suggest trying (out of desparation):
- After switching to bridge mode, Send a reset signal to the Xfinity modem. I do this sometimes when it's having problems, either through the phone (800-COMCAST phone menu option) or via the web portal at https://customer.xfinity.com/#/services/internet ("Restart Modem" button).
- Try setting Advanced / IPV6 to Auto Detect and see if it makes a difference. My experience is Xfinity supports IPV6 and you can select this option but still run IPV4 in your home network.
- BloniarzMar 11, 2022Aspirant
I was able to fix it by switching to CM2000 from Netgear. Got rid of Comcast router. all works great the only task left is to get my Wifi Speed up if possible.
I have a question in regards to RBKE960. Has anyone been able to get more than 640 to 730
Mbps on wireles? If yes how?
Here is my current set up. I have CAT8 runing from the modem to Orbi router and from Router to satelitte 1, Satelitte 2 is WIFI.
CM2000 comcast speed at the modem 1,340 Mbps
Orbi960 Set at CTS2347, Chanell 2.4 at 8, 5 at 44, 6 at 133.
* All Chanells max out at 640 at two feed from ORBI,
DNS 8.8.8.8 and 8.8.4.4
WAN MTU 1500
IPv6 disable
*(note when IPv6 is in auto goes to 6to4 and speed drops 50%)
Any help appriciated
