Bloniarz
Mar 11, 2022Aspirant
NEW RBKE960 WiFI speed improvement help
I have a question in regards to RBKE960. Has anyone been able to get more than 640 to 730 Mbps on wireles? If yes how? Here is my current set up. I have CAT8 runing from the modem to Orbi route...
Mar 11, 2022Guru - Experienced User
what device are you testing on?
The RBKE960 uses quad band.
that's as follows:
1200mbps over 2.4ghz (2.4ghz is a really slow network, it'll never get close to those speeds)
2400mbps over 5ghz
2400mbps over 5ghz (backhaul)
4800mbps over 6ghz.
Keep in mind that those are 4x4 antenna arrangements. Most phones/tablets/pcs are only 1x1 or 2x2 antenna arrangements.
so if you're phone is a 2x2 device, its max link speed is 1200mbps. And thats link speed. thats not throughput. Throughput tends to be 55-65% of link speed. Plus you have to take into account distance (your close to it), obstructions, and interference.
And you have to consider the device you're testing on. Are you testing on an AX device? You didn't put what you're using for speedtesting.
Or what site/app
