jblank1074
Feb 18, 2022Aspirant
New RBR750 dropping ethernet connection every day.
Greetings all, I bought an RBR750 AX4200 from Amazon in late January, sadly, it's been one problem after another. Every evening sometime between the hours of 8:00 pm and 3:00 am, it loses connection ...
Feb 18, 2022Guru - Experienced User
Does the Front LED on the RBR turn ON when the happens?
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- jblank1074Feb 18, 2022Aspirant
Thanks for your reply. The Spectrum box is a Hitron EN2251. Yes, multiple power resets have been performed and nothing positive has resulted from it.
- FURRYe38Feb 18, 2022Guru - Experienced User
What is the CAT# version of the lan cable betweent he modem and router? CAT6 is recommended.
Yes, the front LED is magenta in color and the cable is Cat6.
