jblank1074
Feb 18, 2022Aspirant
New RBR750 dropping ethernet connection every day.
Greetings all, I bought an RBR750 AX4200 from Amazon in late January, sadly, it's been one problem after another. Every evening sometime between the hours of 8:00 pm and 3:00 am, it loses connection ...
jblank1074
Thanks for your reply. The Spectrum box is a Hitron EN2251. Yes, multiple power resets have been performed and nothing positive has resulted from it.
Feb 18, 2022Guru - Experienced User
Does the Front LED on the RBR turn ON when the happens?
What is the CAT# version of the lan cable betweent he modem and router? CAT6 is recommended.
- jblank1074Feb 18, 2022Aspirant
Yes, the front LED is magenta in color and the cable is Cat6.
- FURRYe38Feb 18, 2022Guru - Experienced User
That would inidicate that the RBR has lost connection to the modem or the modem is no longer giving a signal to the RBR or modem has lost service signal from the ISP line. If this happens on a daily basis, seems to be a possible ISP service line issue.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly. Have them check there logs for items seen when you noticed this happening.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.htmlAlso review this and concider updating Orbi FW as last resort:
Thanks but I have already eliminated the modem from being part of the problem. I have a replacement (same model) coming from Amazon, I will see if the behavior continues with the replacement.
