Nov 12, 2019Guru - Experienced User
New RBR850 / RBS850 Firmware Version 3.2.7.2
New FW available for the Orbi RBK852. Bug Fixes: The network topology when using an Ethernet backhaul takes 20 minutes to stabilize The 2.4 GHz wireless network is disabled if the Wi-Fi HT20/...
DoctorA
Nov 12, 2019Luminary
Thank youNice to see that the bug is fixed when Ethernet backhaul used to take 20 minutes to stabilize. This confirms that my RBK 850 is not defective and I was not doing something wrong when I was having problems RBR 850 connected to RBS 850 through Ethernet.
I just checked and it had automatically updated earlier both the Satellite and the Router.
All my 35 plus attached devices are working and it remembered the IP address I reserved for Raspberry Pi. Mine is in Wired backhaul and my wired desktop works at 100% capacity getting 950Mbps. Next to the Satellite, 20 feet away iphone Xs Max link rate is 866Mbps and ookla speed test is 600-650 Mbps. iphone 6 link rate is 780 Mbps on the phone app and ookla connects to the internet at 400Mbps. Next to the Router the number are the same. I can't wait to get and test the new iphone 11 with WiFi6.
FURRYe38 wrote:New FW available for the Orbi RBK852.
Bug Fixes:
- The network topology when using an Ethernet backhaul takes 20 minutes to stabilize
- The 2.4 GHz wireless network is disabled if the Wi-Fi HT20/HT-40 Coexist function is disabled
- The 2.4 GHz guest network does not work if WiFi security is set to WPA3-Personal
Known Issues:
- The Orbi app allows configuring unsupported Wi-Fi security types (WPA2/WPA3 mixed mode)
Download files here:
https://kb.netgear.com/000061398/RBR850-RBS850-Firmware-Version-3-2-7-2\
Also can be seen in the Orbi app. Download the files first for safe keeping. Try the update from the Orbi app first. If it doesnt' work, then you have the FW files saved.
If the RBK852 doesn't continue to work correctly after the FW update, perform a factory reset on the RBS and RBR and setup from scratch. Also if you manually load the FW files, you can do a factory reset and setup from scratch as a suggested method.
Let us know how it works for you...
Awesome. Thanks for letting us know. I'm anxious to test this out on mine as well. Really hoping that they fixed the issue I found with the RBS connected behing a few daisy chained switches.
Looks like there making progress though.
- DoctorANov 12, 2019Luminary
I was wondering if RBK 852 has faster or same iphone internet and Link connection speeds compared to RBK 52. It is interesting why with last year's Xs Max I am getting lower than linked speed to the RBS 850.
FURRYe38 wrote:Awesome. Thanks for letting us know. I'm anxious to test this out on mine as well. Really hoping that they fixed the issue I found with the RBS connected behing a few daisy chained switches.
- FURRYe38Nov 12, 2019Guru - Experienced User
I don't know. I don't have a X phone yet. Still using a iPhone 6sP.
What are you speeds seen at the RBR? Is this the only X phone you have?
What does WiFi Speed Spots app report for the rate seen with the phone connected at near the RBR vs RBS?
Last time I checked my ASUS GT-AX11000 in wireless bridge mode was connecting over 1900Mbps with the RBR. I'll be checking this again.
