Oldgal
May 29, 2024Aspirant
New RBR850 setup problems
Was running an old Hitron modem/router in bridge mode with RBR50 router and satellite and it worked like a charm for 5 years. I was getting reliable 750Mbps, which was a big bump up from the ISP’s ro...
- Jun 02, 2024
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Oldgal
I should add, the new ISP gateway is a Cox technicolor CGM4981, in bridge mode. I have replaced the old Orbi RBR50’s with a new RBR850, router and one satellite. I figured there was no point adding the RBR50’s to new technology. We have a few 6g devices now, so I figured it would be worth the upgrade. Now, not so much.
