Oldgal
May 29, 2024Aspirant
New RBR850 setup problems
Was running an old Hitron modem/router in bridge mode with RBR50 router and satellite and it worked like a charm for 5 years. I was getting reliable 750Mbps, which was a big bump up from the ISP’s ro...
- Jun 02, 2024
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Oldgal
The new ISP gateway is a Cox technicolor CGM4981, in bridge mode. I have replaced the old Orbi RBR50’s with a new RBR850, router and one satellite. I figured there was no point adding the RBR50’s to new technology. We have a few 6g devices now, so I figured it would be worth the upgrade. Now, not so much.
CrimpOn
May 29, 2024Guru - Experienced User
The old RBS50 satellites are not compatible with the new Orbi 850 system, so they would not connect.
The Orbi 850 is a WiFi6 product (802.11ax) which is a definite upgrade from the WiFi5 system. However, it is not WiFi6E which includes the 6G WiFi frequencies.
- OldgalMay 29, 2024Aspirant
Noted and thank you for responding. It’s a bit overwhelming going through the forum - so much info. From what I’ve read, it seems the problem might stem from the FW updating on the RBR and not the RBS. I will start with a reset to factory settings via the web page, as per detailed instructions posted by another user, and do a fresh install through the web page as opposed to the app. Crossing my fingers!
- FURRYe38May 29, 2024Guru - Experienced User
Be sure that if the system needs updating in FW, that the RBS are updated first, then the RBR lastly.
- OldgalMay 30, 2024Aspirant
I actually read your other posts on the forum after I did the install (using the app - my first mistake) and realized that the FW had been updated on the RBR before the RBS. I have your very detailed instructions for factory reset, which I will do when the home office isn’t in use and hopefully that will do the trick. Thank you for responding to my post.
